randydeb
Apr 25, 2023Aspirant
Mesh with powerline?
Hi, I have been using a nighthawk mesh for over a year now with RAX50 router and 2x EAX20 extenders. The distance of the extenders are bit to much to have good speed. My internet speed (spee...
Apr 25, 2023Guru - Experienced User
1. there isn't powerline based mesh extenders from netgear
2. you could use a powerline adapter or moca adapter to connect the extenders and then just put them in access point mode
- randydebMay 24, 2023Aspirant
I have been looking at the Powerline 2000 extender so i can use devices on LAN instead of WIFI.
Want to keep the current mesh setup for the mobile devices, but use powerline for PC's who required better connection.
The EAX20 is on my desk, so i can use the 4 LAN ports as a switch or should i put a separated switch connector to the powerline / pc's?Kind regards,
