SloGoing
Aug 29, 2014Follower
MiFi =>WNCE3001 => WNDR3400 (DD-WRT) Help
**I hope I didn't double post this on accident, if so please delete one. I'm sure this it probably a no brainer to many of you, but right about now that also happens to describe how I am feeling ...
storm_2003
Aug 29, 2014Novice
What is the IP address that you get on your desktop with this setup?
MiFi => WNCE3001 => Desktop = Works Fine
Two suggestions:
1. If you connect the WNCE3001 to WAN port of the WNDR3400 (DD-WRT), - make sure the LAN IP of WNDR3400 is NOT on the same subnet as what you get on your Desktop.
2. If you connect the WNCE3001 to the LAN port of the WNDR3400 (DD-WRT),
- make sure to set the LAN IP of the WNDR3400 on the same subnet as what you get on your Desktop.
Two suggestions:
