Kensing
Sep 29, 2020Aspirant
Misc router in bridge mode before my netgear router + netgear extender router
Will a Misc router (from my ISP) in bridge mode have any negative negative effect on my network?
- Sep 29, 2020
That's a very open ended question.
Overall the network should work fine provided the bridge mode works as it should.
Kensing
Sep 30, 2020Aspirant
If the router in bridge mode does not support wifi 6, but my netgear router and extender does, will they be limited in their wifi 6 capabilities by that bridged router which is first in line?
Sep 30, 2020Guru - Experienced User
what router do you have?
what router do you plan on using for a bridge?
what extender do you have?
why are you setting up a bridge in the first place? it basically disables the wireless on the router as it uses it just for router-----router communication.
