waverunner1
Dec 27, 2020Aspirant
MK62 mesh Device Connection Problem
Got my MK 62 mesh up and running, no problem. Shut down the wifi radios on my ATT router, no problem. Changed the name and password to match the old router and most of my devices connected just fine. ...
waverunner1
Thanks, I'll try that. Why would most devices connect with no problem? Getting very good wifi performance now. 100 times better than the ATT wifi. Why just a few issues?
Dec 27, 2020Guru - Experienced User
Not sure why some devices tolerate a double nat better than others.
I always used to have to unplug my firetv during setting up routers/switchs until I had dhcp/nat set properly or I couldn't set it up.
