Harvinder
May 11, 2021Tutor
MK62 (mr60) WAN speed not great
Hello, I've attached the MR60 WAN port to the modem/router (homehub3000 in Canada) on a Fibe 1GB line. It's placed in the "advanced DMZ" which give the MR60 a public IP. This is great, however, t...
- May 11, 2021
the built in speedtest isn't accurate at speeds >500mbps because it rarely picks the fastest server.
Test with a hardwired in pc/laptop and if you use the speedtest site, test different servers on there as not all can hit gigabit speeds.
May 11, 2021Guru - Experienced User
Test it with qos, access control, parental controls, and traffic monitoring all disabled. If there were enabled,disable them and reboot the router.
