Harvinder
May 11, 2021Tutor
MK62 (mr60) WAN speed not great
Hello, I've attached the MR60 WAN port to the modem/router (homehub3000 in Canada) on a Fibe 1GB line. It's placed in the "advanced DMZ" which give the MR60 a public IP. This is great, however, t...
- May 11, 2021
the built in speedtest isn't accurate at speeds >500mbps because it rarely picks the fastest server.
Test with a hardwired in pc/laptop and if you use the speedtest site, test different servers on there as not all can hit gigabit speeds.
Harvinder
May 11, 2021Tutor
Thanks for the suggestion. The only thing I had turned on was Traffic Meter. I turned it off but still got 600mbps download.
The mesh router I compared it with was TPLink M5, which had a slower wifi speed but higher ethernet speed.
May 11, 2021Guru - Experienced User
how are you testing speed?
Are you using the built in nighthawk speedtest? or what device and testing suite are you using?
- HarvinderMay 11, 2021Tutor
yes, sorry, should have mentioned that. The built-in speedtest tool.
- plemansMay 11, 2021Guru - Experienced User
Ok tried. I have it configured from MR60 -- 8 port GB switch -- MacBook. It got 670mbps. I guess I'll settle for that since not many real-world use cases would warrant those speeds anyway.
Your help was appreciated!
