Harvinder
May 11, 2021Tutor
MK62 (mr60) WAN speed not great
Hello, I've attached the MR60 WAN port to the modem/router (homehub3000 in Canada) on a Fibe 1GB line. It's placed in the "advanced DMZ" which give the MR60 a public IP. This is great, however, t...
- May 11, 2021
the built in speedtest isn't accurate at speeds >500mbps because it rarely picks the fastest server.
Test with a hardwired in pc/laptop and if you use the speedtest site, test different servers on there as not all can hit gigabit speeds.
Harvinder
May 11, 2021Tutor
yes, sorry, should have mentioned that. The built-in speedtest tool.
May 11, 2021Guru - Experienced User
- HarvinderMay 11, 2021Tutor
Ok tried. I have it configured from MR60 -- 8 port GB switch -- MacBook. It got 670mbps. I guess I'll settle for that since not many real-world use cases would warrant those speeds anyway.
Your help was appreciated!
