Harvinder's avatar
May 11, 2021
MK62 (mr60) WAN speed not great
Hello,   I've attached the MR60 WAN port to the modem/router (homehub3000 in Canada) on a Fibe 1GB line. It's placed in the "advanced DMZ" which give the MR60 a public IP. This is great, however, t...
  • plemans's avatar
    May 11, 2021
    the built in speedtest isn't accurate at speeds >500mbps because it rarely picks the fastest server.
    Test with a hardwired in pc/laptop and if you use the speedtest site, test different servers on there as not all can hit gigabit speeds.
