Psychlone
Feb 07, 2021Tutor
MK63 has less speed than XR500 and drops devices
I have a 3700sqft home that I wanted to cure some dead spots. I've been running the XR500 since it very first came out, and although I'm not a fan of DumaOS, it provided pretty good area coverage,...
- Feb 08, 2021
Psychlone wrote:
Thank you for this info plemans
This is info I failed to take into account. I didn't even realize the throughput was so different between them.
So you mention using the mesh as access points for the XR500, does that mean setting the MR60 in access point mode? ---yes, you'd use the mk62's in access piont mode. Because I'm not clear on how this works.
I do understand the concept where the XR500 would act as the router and the mesh would just be additional access points for it, but where can I read how to set that up properly?----the manual goes over how to setup access point mode on the mk 62 system.
And, is there any advantage to doing it this way over using pfsense as the router, and having the XR500 AND the MR60 as AP's?---see bottom
Just trying to decide if I want to box it all back up or try to use it to compliment the system I have or the system I can build around pfsense.---I've heard great things about using pfsense but I've never personally used it so can't attest to how well it compares to an XR500
Thanks again.You could use the pfsense as the router with the xr500 and the mk62 systems as access points. Its possible. The only downfall is half the reason for the XR500 is its gaming features aka reduced ping times and ability to choose game server locations. If you don't use those aspects, then you're not out anything to use the xr500 as an access point.
Feb 07, 2021Guru - Experienced User
Problem is you're not comparing apples to apples.
The XR500 is an AC2600 device. (800mbps link in 2.4ghz and 1733mbps in ac using a 4x4 antenna setup)
The MK system is a AX1800. (600mbps in 2.4ghz and 1200mbps in 5ghz AX using a 2x2 antenna setup).
Problem is, the AC system is higher speed, better antenna configuration, and probably a better cpu. If the device you're testing with aren't AX, the won't connect at the ax link rates. So the AX system's link rates be even lower.
Plus its a base model dual band mesh system. Meaning it has to share bandwidth to supply the mesh nodes. Versus the XR500 doesn't.
And the XR500 is a great AC router. Basically a top end AC router versus a base model mesh system.
If you want a faster system than the XR500, you'd need to move to something like the triband orbi AX system. But even that might be close because it'd need AX devices to connect with to hit max speeds.
Or you can go with the XR500 as the primary router and use the MK system as a wireless access points to add to coverage on the peripheral.
Psychlone
Feb 08, 2021Tutor
So you mention using the mesh as access points for the XR500, does that mean setting the MR60 in access point mode? Because I'm not clear on how this works.
Thanks again.
Thanks again.
