Bigrich64
May 18, 2023Follower
mod. EX6150 not connecting to spectrum fiber opt, wifi
I can’t get Mod. EX6150 to connect to spectrum fiber opt. Wi-Fi. It does not show up in available networks on my iPad or iPhone. any help out there ?
helgastroman
May 19, 2023Aspirant
Troubleshooting steps:
1. Verify that the EX6150 is properly plugged into a power source and turned on.
2. Confirm that your Spectrum fiber optic connection is working properly by checking other devices connected to it.
3. Reset both your EX6150 and your Spectrum fiber optic modem/router by unplugging them for 30 seconds, then plugging them back in.
4. Check if the latest firmware version is installed on your EX6150. You can do this by logging into the device's web interface, navigating to 'Administration' > 'Firmware Upgrade', and clicking 'Check for Updates'.
5. Try placing the EX6150 closer to your Spectrum fiber optic router/modem or directly connect it via Ethernet cable to see if this resolves the issue.
