bkelly1369
Jan 11, 2022Tutor
Model Ex3700, DEVICE will not turn on
Windows 10, Synology RT2600AC wireless router. Multiple devices in the network and everything else is working. I used the WPS button on this device and the router to get it connected. The power li...
- Jan 13, 2022
Regarding the lights, the manual states that the lights indicate quality of connection, not speed.
The manual, as I read it, also clearly states that the DEVICE light should be on when a device is connected.
That has now been shown to be incorrect. When my laptop connects directly to the EX3700 via WIFI, the DEVICE light is lit, but not when an Ethernet cable is connected. A good three hours was spent on hold for about fifteen minutes with the Netgear representative. He did not know how to respond when I mentioned that the light should be lit. Then he put me on hold again to check with his resources and after another 30 minutes I gave up and ended the call.
The device is now in the garage with the solar panel monitor connected to an Ethernet switch, then to the EX3700. The data from the monitor is getting to the manfacturer's web and I can see how the system is performing.
So, the panel is doing what is expected and I am OK with it.
Thank you for your patience.
Jan 11, 2022Guru - Experienced User
If you're hardwiring the ex3700 into your router with a cable, it needs to be setup in access point mode and not setup using wps.
So install it using the installation assistant from the manual and go through the access point mode setup
bkelly1369
Jan 11, 2022Tutor
The initial setup was done without the cable. When the remote device was plugged in, the DEVICE light did not light. I tried two additional cables and cannot get the light on.
The end use is out in the garage connected to the solar panel monitor hardware. It was working with a D-LINK wireless access point, but that one failed and the price of that unit has gone up by about three to four times what it was when purchased. Now I am trying to get this working.
- plemansJan 11, 2022Guru - Experienced User
what router are you connecting it to?
have you tried factory resetting it and setting it up using the installation assistant?
- nielsvdsJan 11, 2022Luminary
The color that you are seeing is just referring to what sync speed is detected that both your connected device supports and on the switch on your router. Amber means 1000 Mbps (1Gbps) and green means 100Mbps. Try to get as close to your router, normally the device LED should be lid when you are using it as extender and not connected with a cable to your router.
- bkelly1369Jan 12, 2022Tutor
The manual says that green light means best connection, amber is good, red means poor.
I hard reset it and configured again and it does not recoginze when an ethernet cable is plugged in.
Time to call Netgear.
