Fally
Feb 22, 2022Initiate
Model EX6110
My extender will not recognise my wifi password. Any suggestions please
Feb 22, 2022Guru - Experienced User
what router is it connected to?
Did you install it using wps?
If so, factory reset it and install it using the installation assistant.
- FallyFeb 22, 2022InitiateTried to factory reset it.
No joy. My devices find it but password will not work. Incorrect password coming up all the time- plemansFeb 22, 2022Guru - Experienced User
"tried to factory reset it"
where did it fail?
You should be holding reset for 7-15 seconds while the device is powered on.
that should reset it and get it back so you can use the installation assistant.
Here's a how to video of the installation assistant. Don't use wps. Some routers WPS is coded poorly
https://www.youtube.com/watch?v=yJVklshxBMk
