Jomtvedt
Sep 25, 2020Aspirant
Model EX7300v2 - need to reset password and extender not showing up in wifi menu for connection
Hello all. Looking for some help. I have a Netgear Nighthawk Extender and I'm having issues with it. First, it doesn't even show up in the wifi menu to choose to connect to - for any devices...
Sep 25, 2020Guru - Experienced User
A couple things.
1. The EX7300 is a mesh extender. Meaning it uses the same ssid/password as the router if setup using mesh or the wps setup method.
2. the password recovery feature has a flaw. that flaw? if you didn't set it up, it still asks the questions but there isn't a right answer. So if it wasn't setup, you don't know the password, or you don't know the answers to the questions, then to get back into the extender, you'd need to factory reset it. that gets you back to the default login and password.
login: admin
password: password
Jomtvedt
Thank you very mucy.
I did the factory reset and it came back online, but i still can't log in even with admin and password as you state. Any other ideas?
Also, if it's online and all lights green shouldn't it be accessible from wifi menu on mobile device?
Thanks.
john
- plemansSep 25, 2020Guru - Experienced User
If its online you should be able to access it but maybe not from the mywifiext . net because the router handles the forwarding. If you log into the router and check your attached devices page (or equivelent), it should show the ip address for the extender if its connected.
Some have needed to hold reset up to 30 seconds.
i'd also try another browser or even pc/laptop. I've seen auto-fill managers overwrite data and cause login issues.
