JADAR1
May 14, 2020Follower
Model R7000P Range
I have the nighthawk model above. The router is located in the house and works well in the house . it does not work well in my backkyard. doe they sell an extender that can help boost my distance....
May 14, 2020Guru - Experienced User
They do sell extenders that can extend range. Something to keep in mind through is that exterior walls do a great job of blocking wifi. Many times its because of the material they're made with. Adobe, metal siding, brick, concrete, foil lined insulation, etc can all block wifi signal. If you're home is one of those that has that type of material, many times its not enough to just add an extender.
