Jjsr2004
Apr 16, 2020Follower
Model WN3000RPv3 new router- incorrect password
Hi Im in the Uk looking for help please. We have upgraded our router but stayed on the same network. Since doing so my wifi extender wont work. We used it previously for our bedroom extension as...
Apr 16, 2020Guru - Experienced User
try resetting it 1 more time. While its fully powered on, push and hold reset. It usually is 7-15 seconds but some devices take up to 30 seconds. The lights will flash/change when held long enough.
the defaults to login to the device (not the wireless password info)
Default login is: admin
default password is: password
I'd recommend hardwiring into the extender and following the install guide and not using wps install. (wps=push button)
what router is it you upgraded to?
