jeffreyP57
Oct 22, 2019Aspirant
Model3110 AC750 WiFi range Extender
My AC750 model 3110 needs updated.However,when I go to the downloads page,it keeps giving me a link to go to.I do,then it does it all over again. help!!
Oct 22, 2019Guru - Experienced User
I just tried it and was able to download the file fine. I would try using a different browser. Try chrome, edge, firefox. Or if you're using one of those, switch and try a different one.
jeffreyP57
Oct 23, 2019Aspirant
When I click on the file,it says corrupt disc image file.I've run sfc/scannow.No help.
- plemansOct 23, 2019Guru - Experienced User
When you click on it to download it or to install it? A better description of where the process is failing will help me instead of just general troubleshooting.
If its for install, you have to extract it first and then follow the firmware install instructions.
https://kb.netgear.com/000057115/How-do-I-update-the-firmware-on-my-NETGEAR-WiFi-Range-Extender
If it still doesn't work, try a different computer.
- jeffreyP57Dec 05, 2019Aspirant
When I try to open the update,it says image disc file corrupted.
- plemansDec 05, 2019Guru - Experienced User
Did you extract it after downloading it?
Make sure to extract it first before trying to upload it.
