windingtrail
Oct 20, 2021Initiate
Modem compatible with MR60 router and satellites
My modem is more than 5 years old and its not keeping pace with my new Nighthawk wifi6 mesh router+satellites (need it to extend to a den outside the house). I don't want to pay modem rental fees wit...
Oct 21, 2021Guru - Experienced User
for docsis 3.1 devices theres:
CM1000
CM1100
CM1200
CM2000
for those with voice:
CM1150V
CM2050V
There's other docsis 3.0 devices but i'd stick with docsis 3.1
how far from the house is the den? Exteriors or homes tend to do a great job blocking wifi as they tend to have materials like metal, cement, foil lined insulution, adobe, brick, etc that all block wifi.
Sometimes its cheaper to just bury an underground cable and connect the home to the den.
windingtrail
Oct 21, 2021Initiate
You are right . The den is an office room , a few feet away in the backyard . The nighthawk satellite alone didn’t work as wifi extender. So we got underground Ethernet cabling work done recently. Ethernet connected to the satellite works fine . I have a good throughput and latency , but of late connection is getting dropped in video calls . We checked with xfinity and found the issue to be the old modem which needs replacement . I will get one of the docsis 3.1 modems from net gear .
