Tom629
Jul 14, 2023Tutor
Most cost effective way to increase wifi coverage with my Netgear Nighthawk X4s R7800?
Hi, I currently have this router and that's wired to another network switch in my living room. My fiance recently moved her desk into a bedroom farthest away from the router. I'd love to replace th...
Kitsap
Jul 15, 2023Master
Tom629 wrote:Hi, I currently have this router and that's wired to another network switch in my living room. My fiance recently moved her desk into a bedroom farthest away from the router. I'd love to replace the switch with either a netgear extender or an orbi? I want the most seamless wifi experience. No 2nd network, no network interference and I have the ethernet cable already setup so I think something like this is doable.
I'm just trying not to break the bank on brand-new orbi mesh system, especially since my nighthawk has been fantastic, up until I needed the wifi to go through my ancient brick home with lathe and plaster walls.
suggestions?
FYI, I also have $150 best buy card I'm planning to use.
You might have to provide more details on your "no 2nd network" requirement.
The most straightforward solution is to add a wired access point in the distant room. This Wi-Fi access could use the same SSID and password as your R7800 on different channels (both 2.4 GHz and 5 GHz bands).
Benefit of also having additional Ethernet connections in the distant room.
Purchase a dedicated access point device or reconfigure a new/refurbished Wi-Fi router from Amazon. Maybe even add Wi-Fi 6 to the mix.
