Tom629
Jul 14, 2023Tutor
Most cost effective way to increase wifi coverage with my Netgear Nighthawk X4s R7800?
Hi, I currently have this router and that's wired to another network switch in my living room. My fiance recently moved her desk into a bedroom farthest away from the router. I'd love to replace th...
Tom629
Aug 16, 2023Tutor
Ok, after much deliberation I bought the EX-6150 extender.
I have my nighthawk router > 4-port switch > EX-6150 extender.
Do I need to be in access point mode or extender mode? Because it’s currently not working
Tom629
Aug 16, 2023Tutor
After a quick google search, my answer is “access point”
Hoping that switch is in extender mode when I get home
- plemansAug 16, 2023Guru - Experienced User
Just an fyi, if hardwired in and running in AP mode, the EX6150 isn't a "mesh" device. You can set it with the same ssid as the primary router, but devices will tend to be sticky and not roam as efficiently as a full mesh system.
Netgears line of mesh extenders only have their smart roaming features enabled if they're running in extender mode. Its a bit of a disappointment but my bet is its netgear not wanting to encroach on their MK/Orbi sales.
- Tom629Aug 16, 2023TutorThis is great to know, tbh. I might unplug it from the switch and try it in extender mode then. And hope the loss in speed isn’t too extreme. If not, I’ll try AP mode as is, and see how annoying the two networks are.
Yeah, you'll lose half your speed in extender mode. You can leave it in AP mode and just set it with the same ssid/password. Devices will still roam to it just not as efficiently.
