GeorgePetter
Mar 08, 2020Aspirant
Motorhome WiFi Extender
Looking for a Campsite WiFi Extender. Aerial on outside of metal body of motorhome. Receives Wifi then amplifies the signal and re transmits the signal via an aerial inside metal body of van. Not a ph...
DexterJB
Mar 11, 2020NETGEAR Moderator
Hi GeorgePetter, you check the link below for our WiFi extenders.
https://www.netgear.com/home/products/networking/wifi-range-extenders/
Dexter
GeorgePetter
Mar 13, 2020Aspirant
It's all very all of the extenders. But so far there isn't one that runs from 12Vdc. Many are 110vac or 230vac. That I have found. Also it from outdoors to inside a motorhome. Not room to room extension booster.
