GeorgePetter
Mar 08, 2020Aspirant
Motorhome WiFi Extender
Looking for a Campsite WiFi Extender. Aerial on outside of metal body of motorhome. Receives Wifi then amplifies the signal and re transmits the signal via an aerial inside metal body of van. Not a ph...
DexterJB
Mar 11, 2020NETGEAR Moderator
Hi GeorgePetter, you check the link below for our WiFi extenders.
https://www.netgear.com/home/products/networking/wifi-range-extenders/
Dexter
GeorgePetter
Mar 13, 2020Aspirant
Not found an outdoor to indoor extender 12vdc. Most are room to room extender
- DexterJBMar 23, 2020NETGEAR Moderator
Hi, you may want to look into the outdoor Orbi linked below.
https://www.netgear.com/orbi/rbs50y.aspx
Dexter
