nevyan's avatar
nevyan
Follower
Jun 29, 2013
Moved and now cannot configure N150 WNR1000 at new home
I recently moved from Georgia to Kentucky and changed service providers (Knology --> Mediacom). My wired and wireless network in Georgia worked fine with my two laptops and ipad. I was using the same wireless router (Netgear N150 WNR1000). When I tried to setup my wired and wireless network in Kentucky it has been a failure.
Both Laptops --> connected by cable to Mediacom provided modem works fine
Both Laptops --> conneceted by cable to N150 WNR1000 --> connected by cable to Mediacom provided modem does NOT work
Needless to say the wireless networking is not working either.
Using either the provided CD for setup or by entering http://www.routerlogin.net and following the setup does no resolve the issue.
IPCONFIG /ALL when (primary) laptop connected to Mediacom provided modem by cable:
Windows IP Config:
Host Name: Jamie-Laptop
Primary DNS Suffix:
Node Type: Broadcast
IP Routing Enabled: No
WINS Proxy Enabled: No
Wireless LAN Adapter Wireless Network Connection:
Connection-specific DNS Suffix:
Description: Atheros AR9285 802.11b/g/n WiFi Adapter
Physical Adress: 00-1B-B1-82-FD-68
DHCP Enabled: Yes
Autoconfiguration Enabled: Yes
IPv4 Address: 172.16.0.3 (Prefferred)
Subnet Mask: 255.255.255.0
Default Gateway 172.16.0.1
DHCP Server: 172.16.0.1
DHCPv6 IAID: 4194374889
DHCPv6 Client DUID: 00-01-00-01-14-73-29-E6-F0-4D-A2-AA-D0-59
DNS Server: 172.16.0.1
NetBIOS Over TCP/IP: Enabled
Ethernet Adapter Local Area Connection:
Connection Specific DNS Suffix:
Description: Atheros AR8152 PCI-E Fast Ethernet Controller (NDIS 6.20)
Physicial Address: F0-4D-A2-AA-D0-59
DHCP Enabled: Yes
IPv4 Address: 173.188.177.172 (prefferred)
Subnet Mask: 255.255.248.0
Default Gateway: 173.18.176.1
DHCP Server: 108.178.214.7
DHCPv6 IAID: 300961186
DNS Server: 97.64.209.36 97.64.168.13
NetBIOS Over TCP/IP: EnableD
IPCONFIG /ALL when (primary) laptop connected to N150 WNR1000 by cable and to Mediacom provided modem by cable:
Windows IP Config:
Primary DNS Suffix:
DHCP Enabled: Yes
DHCP Enabled: Yes
IPv4 Address: 172.16.0.2 (prefferred)
Default Gateway: 172.16.0.1
