Mt3
Aug 08, 2020Follower
Moved to new home nighthawk X6S
I have moved from the original place I set the unit up at, at my new place it will not connect to new router. I tried the trouble shooting and it stil says cant locate the new router.
Aug 09, 2020Guru - Experienced User
Mt3 wrote:I have moved from the original place I set the unit up at, at my new place it will not connect to new router. I tried the trouble shooting and it stil says cant locate the new router.
Which router are you using?
What modem/gateway are you connecting it to?
Did you factory reset the router and then follow the install guide?
It can be found at netgear.com/support/ go there and type in the model number and it'll take you to the support site.
