DGordonB's avatar
Feb 15, 2022
MR60 can't obtain IP after SSID name change
System config. comcast internet, netgear cm600 modem, nighthawk MK63 mesh router. we had a nighthawk MK63 for ~18 months. it failed to connect to the internet a couple weeks ago. a quick test...
  • DGordonB's avatar
    DGordonB
    Feb 23, 2022
    Got this from support and it worked for me. I also rebooted the modem and router after changing the settings.
    Good day! Try to change the wireless channel of the router. Below are the steps.
    1. Launch a web browser from a computer or mobile device that is connected to your mesh network.
    2. Enter http://www.routerlogin.net. A login window opens.
    3. Enter the router admin user name and password. The user name is admin. The password is the one that you specified the first time that you logged in. The user name and password are case-sensitive.
    The BASIC Home page displays.
    4. Select Wireless. The Wireless Settings page displays
    5. Change the channel of the 2.4 GHz into 6. Then for the 5 GHz change it into 161 or 48.
    6. Apply the changes.
