cmtmaloney
Apr 24, 2020Aspirant
MR60 Nighthawk mesh 6 wifi won't connect Amazon prime netflix
Can get the router up and running. Computers seem to hook ok and are able to use the internet but my TV's will connect but when try to go to Amazon or Netflix on them there is a connection error. Also...
Apr 24, 2020Guru - Experienced User
What modem/gateway are you connected to?
cmtmaloney
Netgear adsl modem not sure what model
