cmtmaloney
Apr 24, 2020Aspirant
MR60 Nighthawk mesh 6 wifi won't connect Amazon prime netflix
Can get the router up and running. Computers seem to hook ok and are able to use the internet but my TV's will connect but when try to go to Amazon or Netflix on them there is a connection error. Also...
Apr 24, 2020Guru - Experienced User
cmtmaloney wrote:
Netgear adsl modem not sure what model
This is kind of key.
Reason why is some services have issues with double nat's.
https://kb.netgear.com/30186/What-is-Double-NAT
If youre going a modem/router combo device to the MR60, you can run into those issues if one of them doesn't have router mode disabled.
cmtmaloney
So should I change the modem to modem only and then do i have to put the PPoE login into the router or leave it still in the modem/
