maginoodle's avatar
maginoodle
Follower
Oct 22, 2022
MR60 not connecting to NTP server
Hi everyone,
I’ve had a great run with my MR60 since getting it early last year. I have recently changed internet providers to Dodo (I’m in Australia) and am using the modem they supplied me which is a https://www.tp-link.com/au/service-provider/xdsl/vx220-g2v/ . I have found that I
can’t watch Netflix or Stan on my tv but Disney+ works fine so it definitely has internet connection through the MR60, to check if it was a mesh or modem problem I ran a temporary Ethernet cable from the modem to the tv( from upstairs to downstairs) and could stream Netflix and Stan so I know it’s not a problem with the modem. I can’t swap back to the original modem as it was supplied by my old internet provider and it was about six years old. I logged into the MR60 and found a warning that the NTP server was not connecting and as we have switched to daylight savings time I believe that is causing the issue. I tried another few servers (all in Aus) but none would connect . I can’t find how to disable the NTP requirement or know whether Dodo is blocking all NTP servers.
Any help appreciated
Cheers Shane
No RepliesBe the first to reply
