TB0000
Dec 01, 2021Follower
MR60 wont connect to 3 out of my 4 satellites after hard reset of router
All 4 satellites were connected and solid blue leds prior to hard reset. I reset the router because the system was dropping out quiet regulararly (noticed it primarily on my 10x shelley smart home r...
Dec 02, 2021Guru - Experienced User
What firmware is on the router and the satellites?
You can hardwire a pc/laptop into the disconnected satellites. when hardwired in, their default address should be 192.168.1.250
You potentially can log into them to check their firmware version.
Another thing you can try is hardwiring them in to update/sync them. Then disconnect and re-add them.
