Agr0_'s avatar
Agr0_
Follower
Jun 22, 2024
MR70 Satellites keep losing connection
Within the last few months I had picked up a Netgear MR70 mesh system from Costco however I am just about at my witts end with the system and am on the verge of returning it. When using the system with the primary router on the main floor and a satellite about 28ft away up stairs (to have a wired connection to my pc) at random times the satellite will lose connection to the main router and change from the blue connected status to amber for about 30 seconds then partially reconnect and eventually switch back to blue before eventually repeating this process over again and causing some irritation. I have tried the below steps with no luck and am still experiencing the exact same issues DAILY.
- Full reset and configure through web UI
- Connecting different satellites at setup
- Moving Satellites to the same floor still within the 30ft suggestion
- Reset Modem (Arris Surfboard SB8200)
- New cat6 cable
- Logs indicated Fraggle / DOS attacks, disabled port and dos scanning
- Tried set QOS values.
Does anyone have any suggestions on what else to do? TYIA!
No RepliesBe the first to reply
