dormio's avatar
dormio
Follower
Jun 04, 2024
MS80 compatibility with EasyMesh routers
My fiber company makes me rent an Arris NVG443B modem/router combo, and it has the ability to operate in EasyMesh mode. If I buy Nighthawk mesh add-on satellites (MS80), will they be compatible with ...
  • plemans's avatar
    Jun 04, 2024
    In theory, they're listed on the easy mesh approved list. But I've never seen anyone try it.
    I haven't.
    The biggest hurdle is price. Right now on amazon, a MS80 satellite is $122 for a single satellite. You can get the MK83 kit for $146. so if you were planning on having more than 1 satellite, its easy which one to choose. Plus then, if it needs the router, you have it. Or you could put the Arris in passthrough mode (modem only) and just use the netgear kit. That'd be the router I'd go for.
