Jay968's avatar
Jay968
Apprentice
Jan 11, 2020
Multiple AC1750 WiFi Mesh Extenders in home
Very simple question; If I add a second or third AC1750 Mesh Extender to a second and/or third room in my home and walk through with a WiFi connected cell phone, will the system hand off the phone f...
  • plemans's avatar
    Jan 12, 2020
    Between the router and extender. You can read into it as you will. I've said my part and explained what you'd need to do to get it to work. I've also recommended going with a mesh setup. Do as you will.
