strakerc
Oct 05, 2020Aspirant
Multiple EAX80s - Fastlane to Prevent Connection Issues
Hi there, There are a lot of threads about using multiple EAX80s to make a mesh network in a large home, and all seem to say "don't do that! They'll connect to themselves, that's the problem!" But...
strakerc
See attached screenshot of only one device despite two on the network. After turning the second one off for a while, it is now defaulting back to 192.168.1.250 IP address, while the other is stable at 192.168.1.9 (as can be seen in the screenshot).
- plemansOct 06, 2020Guru - Experienced User
Why don't you just set one of them with their own unique ssid?
- strakercOct 11, 2020Aspirant
Why should I have to do that? And why would that help with connectivity to the main router?
- plemansOct 12, 2020Guru - Experienced User
Problem with extenders is that they aren't a full mesh system like orbi with a router controlling the system.
so they can end up connected to each other if they're to close to each other or if the router's signal isn't always stable (when it drops the extenders can search/find each other)
If you're in one of those circumstances, having 1 with its own unique ssid can increase stability because they won't end up connecting to each other.
Its why we/I usually recommend people use a full mesh system like orbi if they're needing more than 1 extender.
