fpefpe
Apr 03, 2023Aspirant
multiple entenders
I have 2 ex6120 and I wanted to connect them to my router --- I am having an issue using the wpa button, so I want to use the browser to configure the extender --- the manual says to connect to the extender using the network NETGEAR_EXT, but if I have 2 how do I know which extender I am connecting to?
1 Reply
leave one powered off while setting up the first. Then power it off after its setup and setup the 2nd one.
I generally don't advise using more than 1 extender. Usually if you're needing more than 1, I advise people to move to an actual mesh system like netgear orbi or MK nighthawk as then something is controlling the system. It'll be more stable versus using multiple extenders.
