MattDoc
Sep 17, 2019Aspirant
Multiple EX7500 Range Extenders
Hi, Does anyone know if you can incorporate two or more EX7500's into the same set-up (home)? I have read that with traditional range extenders that can cause conflicts, but I imagine with ...
MattDoc
Hi Plemans,
Thank you for the explanation.
Therefore, the EX7500 isn't really a Mesh range extender; it's just an extender that allows for a single ssid. Shame, I bought it on the basis that it was a true Mesh extender. Oh well!
Thanks
Matt
Sep 17, 2019Guru - Experienced User
If you have the option to hardwire one of them, it'd work great. Problem when you start daisy chaining extenders is that your latency and potential errors increase.
As well as they are designed to function with 1 in a network. When you start buying multiple, you might as well as went with an orbi setup as you'll be hitting that price range. Then you get something designed to do what you're attempting.
