gascomp
Sep 16, 2014Aspirant
multiple wifi extenders on one network?
Have installed one WN1000RP on home network that works fine but wanted to extend coverage to far corner of house. Purchased duplicate extender and when I try to use it the LED shows strong wifi signa...
gascomp
Sep 23, 2014Aspirant
Tried each extender separately and each works OK but when you plug in the second one, one of the two will begin indicating no wifi signal. Could not figure out how to put each on a separate channel from the router so will just give it up as a bad idea. Thanks for your suggestion.
