nizzy99
Feb 17, 2012Novice
Multiple WNAP210
I am currently trying to Configure 3 WNAP210's as Wireless Repeaters, I have a 3 story townhouse and would like 1 AP on each floor for good coverage and I think repeater is the right way about it with...
nizzy99
Feb 17, 2012Novice
Foredem,
thanks for the reply so if im using them hard wired do you suggest I just switch off repeating and bridging and then configure them all with the exact same config except maybe make AP1 channel 1, AP2 Channel 6, AP3 Channel 11.
I use skype alot and VPN so dont want walking between floors to cause it to drop out.
Im using hard wired so i can use the POE on the WNAP210
Thank you again for your reply
