HistoryLAL's avatar
HistoryLAL
My AC1750 Dual Band WiFI Mesh Extender will not bring up a web page even when all lights show green
  • plemans's avatar
    What extender is it? AC1750 is a speed.
    What router is it connected to?
    What method of setup did you use? wps or the installation wizard?
    • HistoryLAL's avatar
      HistoryLAL
      LYONS REPLY
      NETGEAR Model number EX6250
      Router is ARRIS DG2460
      Used WPS
      • plemans's avatar
        Try factory resetting the EX6250.
        Push and hold reset for 7-15 seconds while powered on. the lights should change/flash when held long enough.
        then install using the installation assistant.
        what happens after following that?
        also, keep in mind the EX6250 is a mesh extender. meaning in default setup is uses the same ssid as the router. If there's a different ssid showing up, it might not be yours. It might be a different device simply being picked up.
