philspo
Feb 17, 2022Aspirant
My AC3000 Nighthawk X6S Tri Band WiFi Mesh Extender goes down
Hi My AC 3000 Nighthawk X6S model EX8000 keeps shutting down. It works perfectly for several hours and then disapears from the network and the white leds on the front are off. Its annoying because...
- Feb 24, 2022
Hi,
Thank you very much for your input.
I will try your suggestions and maybe install a UPS as well.
The problem didn't occur again these last days.
Thanks again
Feb 17, 2022Guru - Experienced User
What firmware version is on it?
Did this just start?
Is it a new device?
- philspoFeb 17, 2022Aspirant
Hi
Thanks for the answer.
The firmware is the latest available (can't remember the number ; I'm not home right now)
I think the problem is present since the beginning. I bought the divice last july.
I live in the country. There are regularly some brief power cut-offs here (for a fraction of a second). Could it be the reason ?
I'm not sure about that, but if yes, is there a way to make the device restart automatically after a cut-off ?
Thanks again
Philippe
