SQ22
Sep 10, 2022Follower
My EX2700 Range Extender won't work after Router change
I have done a factory reset, and Extender appears to have connected to Router - correct lights on.
When I try to attach my laptop, it states 'unable to connect'. I have also tried using the 192.168.1.250 method, but this failed miserably too. Any help gratefully received.
1 Reply
When you installed it, what method of install did you use? WPS?
What router are you connecting it to?
Try factory resetting it. Push and hold reset for 7-15 seconds while powered on.
After the reset, install using the installation assistant and NOT wps.
