Doragh22
Jan 29, 2021Aspirant
My EX6120 keeps disconnecting every night. How do I fix it
My ex6120 disconnects every night. How can I fix the problem please
Jan 29, 2021Guru - Experienced User
What router is it connected to?
What firmware is on the extender?
what method of setup did you use? wps or the installation assistant?
Have you tried setting it with a static ip address in the router?
- Doragh22Jan 30, 2021AspirantThanks for the reply đ
Virgin media super hub 3
I haven't touched the firmware
With wps and wouldn't know how to do that last one? Sure I could work ot out though......thanks đ- plemansJan 30, 2021Guru - Experienced User
Seems like I see a lot of issues on here with the virgin hub 3.
I'd try installing the extender using the installation assistant and not using wps.
The virgin manual should have instructions on setting a static ip address
