Doragh22
Jan 29, 2021Aspirant
My EX6120 keeps disconnecting every night. How do I fix it
My ex6120 disconnects every night. How can I fix the problem please
Doragh22
Jan 30, 2021Aspirant
Thanks for the reply 👍
Virgin media super hub 3
I haven't touched the firmware
With wps and wouldn't know how to do that last one? Sure I could work ot out though......thanks 😊
Jan 30, 2021Guru - Experienced User
Seems like I see a lot of issues on here with the virgin hub 3.
I'd try installing the extender using the installation assistant and not using wps.
The virgin manual should have instructions on setting a static ip address
