craigrainford
Sep 09, 2021Tutor
My EX7300 stopped working :-(
From time to time by EX7300 will just stop broadcasting so I just perform a factory reset and reconfigure - I find this is the quickest way to solve it (until now). After I perform the factory re...
- Sep 09, 2021
default ip address during setup is 192.168.1.250
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
Sep 09, 2021Guru - Experienced User
do any other lights come on?
Or just the power light?
did the switch on the side get flipped over to access point mode?
- craigrainfordSep 09, 2021TutorJust the power light.
It’s definitely still in “extender” mode.
Anybody know what the default IP is? Thinking I can just my laptop a static IP on that range and connect that way?!- plemansSep 09, 2021Guru - Experienced User
- craigrainfordSep 14, 2021Tutor
Using the default IP did the trick.
