craigrainford
Sep 09, 2021Tutor
My EX7300 stopped working :-(
From time to time by EX7300 will just stop broadcasting so I just perform a factory reset and reconfigure - I find this is the quickest way to solve it (until now). After I perform the factory re...
- Sep 09, 2021
default ip address during setup is 192.168.1.250
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
craigrainford
Sep 09, 2021Tutor
Just the power light.
It’s definitely still in “extender” mode.
Anybody know what the default IP is? Thinking I can just my laptop a static IP on that range and connect that way?!
Sep 09, 2021Guru - Experienced User
