vectormanarcade
Dec 14, 2020Aspirant
My EX8000 just has solid 2.4 light and won't reset. seems dead.
My Nighthawk X6S AC3000 EX8000 all of a sudden went dead and just shows the 2.4Ghz light. Rebooting it does nothing - same light only lit. Holding in reset button flashes the power light red but do...
Dec 14, 2020Guru - Experienced User
Push and hold the reset for up to 30 seconds.
then give it a couple minutes to fully boot.
Can you hardwire in and access using a wired connection? (disable the wifi on the device you connect to it)
You can also try access it using the default 192.168.1.250 address when hardwired in
