vectormanarcade
Dec 14, 2020Aspirant
My EX8000 just has solid 2.4 light and won't reset. seems dead.
My Nighthawk X6S AC3000 EX8000 all of a sudden went dead and just shows the 2.4Ghz light. Rebooting it does nothing - same light only lit. Holding in reset button flashes the power light red but do...
ashdeini
Mar 02, 2021Aspirant
Same issue here. Looking for solutions.
- LinaCifuApr 13, 2021Aspirant
I have the same problem, did you find a solution for it?
- vectormanarcadeApr 13, 2021Aspirant
I hate to say it, but I don't remember exactly what resolved the issue. I got so frustrated with the situation that I just googled what is the BEST cable modem, what is the BEST wifi router, and then I bought those for like $400 each. Then I did complete resets with the little reset button on all of my EX8000s and reprogrammed them all one by one. Everything is working well now. I don't know which of these things fixed it, but I suspect that the fact that I had a 4 or 5 year old cable modem and a 3 or 4 year old router were the problem. Now i have the best of the best and life is good. I'm now running 5 of these EX8000s blasting into the atmosphere and I have wifi everywhere.
- CptnMorganApr 19, 2021TutorHaving the same problem. But mine is also making a cyclic ticking noise like a hard disk trying to seek.
For how much this thing cost it was a huge scam and someone should have started a class action lawsuits by now. The millions of dollars netgear made off this and provided zero updates or customer support beyond recommending factory reboots. What a huge and utter public scam of the tech community.
This unit should have been the best extender on the market but it's been nothing but a huge pain since day one. The app can't be used. The firmware should not be attempted to upgrade. Don't ever turn it off cause it might never work again.
