vectormanarcade
Dec 14, 2020Aspirant
My EX8000 just has solid 2.4 light and won't reset. seems dead.
My Nighthawk X6S AC3000 EX8000 all of a sudden went dead and just shows the 2.4Ghz light. Rebooting it does nothing - same light only lit. Holding in reset button flashes the power light red but do...
Dec 14, 2020Guru - Experienced User
Push and hold the reset for up to 30 seconds.
then give it a couple minutes to fully boot.
Can you hardwire in and access using a wired connection? (disable the wifi on the device you connect to it)
You can also try access it using the default 192.168.1.250 address when hardwired in
Mhuelskamp
Nov 18, 2021Initiate
Plugging directly into the device and setting up works.
