danneboi
Apr 13, 2022Guide
My extender stopped working all of a sudden
Hi! I've been using a WN3000RP wi-fi extender for the last year or so and it's worked perfectly. Today however it stopped working. I've done a factory reset and it was no problem for the ex...
danneboi
Apr 13, 2022Guide
The router it's connected to is a Sagemcom Fast5370e.
I used the assistant on mywifiext. net.
When I log into mywifiext. net it says that it cant connect to the Existing Network. I've also tried to move the extender closer to the router without success.
Some of my translastions might be wrong since I use it in swedish.
Apr 13, 2022Guru - Experienced User
I have a passionate hatred for sagemcom devices. We see all kinds of issues on them.
You can try setting it up using wps. Sometimes that works when the installation assistant struggles.
- danneboiApr 13, 2022Guide
It's just wierd since it has been working perfectly for a year.
Also what does the {"reset": "1"} means. I've seen it in a few threads here but no solution for it.
- plemansApr 13, 2022Guru - Experienced User
danneboi wrote:
It's just wierd since it has been working perfectly for a year.----its part of why I struggle with sagemcom. They push updates and their firmware is garbage.
Also what does the {"reset": "1"} means. I've seen it in a few threads here but no solution for it.----got a screensnip of it? not sure what you're referring to.
Ah, if that's the case your hatred makes sense 🙂
I linked a picture of the code.
