danneboi
Apr 13, 2022Guide
My extender stopped working all of a sudden
Hi! I've been using a WN3000RP wi-fi extender for the last year or so and it's worked perfectly. Today however it stopped working. I've done a factory reset and it was no problem for the ex...
danneboi
Apr 13, 2022Guide
It's just wierd since it has been working perfectly for a year.
Also what does the {"reset": "1"} means. I've seen it in a few threads here but no solution for it.
Apr 13, 2022Guru - Experienced User
danneboi wrote:
It's just wierd since it has been working perfectly for a year.----its part of why I struggle with sagemcom. They push updates and their firmware is garbage.
Also what does the {"reset": "1"} means. I've seen it in a few threads here but no solution for it.----got a screensnip of it? not sure what you're referring to.
- danneboiApr 13, 2022Guide
Ah, if that's the case your hatred makes sense 🙂
I linked a picture of the code.
- plemansApr 13, 2022Guru - Experienced User
what firmware is on the extender?
was trying to check that models forums for issues with adding extenders but sadly its all in different languages. Tough to peruse through and find any tips/tricks for that model router.
