danneboi
Apr 13, 2022Guide
My extender stopped working all of a sudden
Hi! I've been using a WN3000RP wi-fi extender for the last year or so and it's worked perfectly. Today however it stopped working. I've done a factory reset and it was no problem for the ex...
Apr 13, 2022Guru - Experienced User
danneboi wrote:
It's just wierd since it has been working perfectly for a year.----its part of why I struggle with sagemcom. They push updates and their firmware is garbage.
Also what does the {"reset": "1"} means. I've seen it in a few threads here but no solution for it.----got a screensnip of it? not sure what you're referring to.
danneboi
Apr 13, 2022Guide
Ah, if that's the case your hatred makes sense đ
I linked a picture of the code.
- plemansApr 13, 2022Guru - Experienced User
what firmware is on the extender?
was trying to check that models forums for issues with adding extenders but sadly its all in different languages. Tough to peruse through and find any tips/tricks for that model router.
- danneboiApr 13, 2022Guide
Yeah, I understand it's hard when it's the wrong language. đ
I wasn't successful in connecting it using WPS. I've sent a mail to Sagemcom about any possible update that might have interfered with the extender/router relationship.
I found the firmware on the extender and it is V1.0.2.80.
I appreciate your help man đ
I don't know what firmware and I can't find it on mywifiext. com
I will factory reset it again and try to connect it using wps.
