O__B
Jan 03, 2022Aspirant
My N300 Wifi Range Extender (Model EX2700) does not work despite being set up properly.
This is my second time using this product. I had to replace the first one due to one of the antenna coming out, and now I'm having problems with this one despite it working fine for a while. About ...
Jan 04, 2022Guru - Experienced User
What is the distance between the router and extender(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
What channels are you using on the main host router?
O__B
Jan 04, 2022Aspirant
The distance definitely isn't the problem as in the past it has worked absolutely fine from there, and I myself am not too far from the extender either. The product seems like it's fine so I have no clue as to why I am unable to connect to the extension network.
